SVP, quelqu'un peut me dire ou je peux trouver la description détaillé de LDM (LOAD MESSAGE).
Merci pour votre aide
LOAD MESSAGE ( LDM )
Le mieux c'est de regarder directement le chapitre 6 du manuel de Ground Handling Operator Training disponible en ligne sous forme de PDF ici :
http://www.scribd.com/doc/7276645/Messages
C'est à partir de la page 10/25 jusqu'à la page 13.
Comme pour les METAR/TAF c'est vraiment pas compliqué. Il suffit juste d'un peu d'entrainement pour connaitre l'ordre des items et déchiffrer rapidement les messages.
Rapide présentation "merci Google" du LDM :
Source : http://www.niko.hr/Weight%20and%20Balance_tekst.htmWithin the Weight and Balance module, depending on the type of user sign in, many changes can be made. This includes changes to aircraft information, which will affect the CDB permanently or semi-permanently. Also alterations may be made after any aircraft departure. It is possible for the load controller to add any last minute changes (e.g. late passenger, late offload of cargo etc.) to the final Load Message and Load sheet after the departure.
With regard to departure, arrival, delay or load messages, the AS system is fully automated in the creation of these messages using the details already input for the particular flight e.g. For the Load message (LDM) an automatic process is used whereby the user activates a function post-departure to bring all passenger, baggage, cargo etc. figures directly into LDM mask and all the user has to do is press ?send?. For the delay messages, within the mask there is a drop down list with delay codes, sub delay codes and explanations to choose from. The message mask contains the SITA addresses required and also a drop down list of all other SITA addresses that possibly may be required.
